Uncompressing Linux... done, booting the kernel.
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.18.0-trunk-rpi (debian-kernel@lists.debian.org) (gcc version 4.7.2 (Debian 4.7.2-5+rpi1) ) #1 PREEMPT Debian 3.18.5-1~exp1+rpi19 (2015-08-08)
[ 0.000000] CPU: ARMv6-compatible processor [410fb767] revision 7 (ARMv7), cr=00c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT nonaliasing instruction cache
[ 0.000000] Machine: BCM2708
[ 0.000000] cma: Reserved 8 MiB at 0x07000000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0x12 bcm2708.serial=0x2ef3dee5 smsc95xx.macaddr=B8:27:EB:F3:DE:E5 bcm2708_fb.fbswap=1 bcm2708.disk_led_gpio=47 bcm2708.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0xec00000 vc_mem.mem_size=0x10000000 dwc_otg.lpm_enable=0 console=ttyAMA0,115200 kgdboc=ttyAMA0,115200 console=tty1 elevator=deadline root=/dev/mmcblk0p2 rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Memory: 107696K/131072K available (5769K kernel code, 477K rwdata, 1696K rodata, 332K init, 446K bss, 23376K reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
[ 0.000000] vmalloc : 0xc8800000 - 0xff000000 ( 872 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc8000000 ( 128 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0752838 (7467 kB)
[ 0.000000] .init : 0xc0753000 - 0xc07a6000 ( 332 kB)
[ 0.000000] .data : 0xc07a6000 - 0xc081d5f4 ( 478 kB)
[ 0.000000] .bss : 0xc081d5f4 - 0xc088ce7c ( 447 kB)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:522
[ 0.000024] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2147483648000ns
[ 0.000073] Switching to timer-based delay loop, resolution 1000ns
[ 0.000362] Console: colour dummy device 80x30
[ 0.001679] console [tty1] enabled
[ 0.001728] Calibrating delay loop (skipped), value calculated using timer frequency.. 2.00 BogoMIPS (lpj=4000)
[ 0.001814] pid_max: default: 32768 minimum: 301
[ 0.001952] Security Framework initialized
[ 0.002079] AppArmor: AppArmor disabled by boot time parameter
[ 0.002136] Yama: disabled by default; enable with sysctl kernel.yama.*
[ 0.002303] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.002369] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.003477] Initializing cgroup subsys memory
[ 0.003571] Initializing cgroup subsys devices
[ 0.003637] Initializing cgroup subsys freezer
[ 0.003695] Initializing cgroup subsys net_cls
[ 0.003751] Initializing cgroup subsys blkio
[ 0.003804] Initializing cgroup subsys perf_event
[ 0.003864] Initializing cgroup subsys net_prio
[ 0.003994] CPU: Testing write buffer coherency: ok
[ 0.004217] ftrace: allocating 19046 entries in 56 pages
[ 0.125347] Setting up static identity map for 0x537ce8 - 0x537d44
[ 0.141900] devtmpfs: initialized
[ 0.160707] VFP support v0.3: implementor 41 architecture 1 part 20 variant b rev 5
[ 0.172083] pinctrl core: initialized pinctrl subsystem
[ 0.173193] NET: Registered protocol family 16
[ 0.178806] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.189601] cpuidle: using governor ladder
[ 0.201669] cpuidle: using governor menu
[ 0.202229] bcm2708.uart_clock = 3000000
[ 0.202308] of_platform_populate failed: -22
[ 0.207899] hw-breakpoint: found 6 breakpoint and 1 watchpoint registers.
[ 0.207976] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.208055] mailbox: Broadcom VideoCore Mailbox driver
[ 0.208229] bcm2708_vcio: mailbox at f200b880
[ 0.208864] bcm_power: Broadcom power driver
[ 0.208927] bcm_power_open() -> 0
[ 0.208960] bcm_power_request(0, 8)
[ 0.709709] bcm_mailbox_read -> 00000080, 0
[ 0.709765] bcm_power_request -> 0
[ 0.710091] Serial: AMBA PL011 UART driver
[ 0.710331] dev:f1: ttyAMA0 at MMIO 0x20201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 1.130540] console [ttyAMA0] enabled
[ 1.186524] usbcore: registered new interface driver usbfs
[ 1.192346] usbcore: registered new interface driver hub
[ 1.197910] usbcore: registered new device driver usb
[ 1.205799] Switched to clocksource stc
[ 1.314111] NET: Registered protocol family 2
[ 1.320089] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 1.327377] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 1.333856] TCP: Hash tables configured (established 1024 bind 1024)
[ 1.340387] TCP: reno registered
[ 1.343714] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 1.349647] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 1.356419] NET: Registered protocol family 1
[ 1.361503] Unpacking initramfs...
[ 2.144416] Freeing initrd memory: 5236K (c7ad3000 - c7ff0000)
[ 2.164259] bcm2708_dma: DMA manager at f2007000
[ 2.169378] bcm2708_gpio: bcm2708_gpio_probe c07b5ae0
[ 2.175325] vc-mem: phys_addr:0x00000000 mem_base=0x0ec00000 mem_size:0x10000000(256 MiB)
[ 2.186485] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 2.192943] audit: initializing netlink subsys (disabled)
[ 2.198643] audit: type=2000 audit(1.884:1): initialized
[ 2.220812] zpool: loaded
[ 2.224347] VFS: Disk quotas dquot_6.5.2
[ 2.228865] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 2.238339] msgmni has been set to 236
[ 2.247218] alg: No test for stdrng (krng)
[ 2.252120] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[ 2.260214] io scheduler noop registered
[ 2.264422] io scheduler deadline registered (default)
[ 2.270342] io scheduler cfq registered
[ 2.276326] BCM2708FB: allocated DMA memory 47400000
[ 2.281570] BCM2708FB: allocated DMA channel 0 @ f2007000
[ 2.293267] Console: switching to colour frame buffer device 82x26
[ 2.306705] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[ 2.316938] uart-pl011 dev:f1: no DMA platform data
[ 2.325045] vc-cma: Videocore CMA driver
[ 2.331213] vc-cma: vc_cma_base = 0x00000000
[ 2.338096] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 2.345613] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 2.354358] vchiq: vchiq_init_state: slot_zero = 0xc7000000, is_master = 0
[ 2.364483] usbcore: registered new interface driver smsc95xx
[ 2.373499] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 2.581866] Core Release: 2.80a
[ 2.587105] Setting default values for core params
[ 2.593907] Finished setting default values for core params
[ 2.801810] Using Buffer DMA mode
[ 2.807157] Periodic Transfer Interrupt Enhancement - disabled
[ 2.815013] Multiprocessor Interrupt Enhancement - disabled
[ 2.822604] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 2.828931] Dedicated Tx FIFOs mode
[ 2.834897] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xc7414000 dma = 0x47414000 len=9024
[ 2.848678] FIQ FSM acceleration enabled for :
[ 2.848678] Non-periodic Split Transactions
[ 2.848678] Periodic Split Transactions
[ 2.848678] High-Speed Isochronous Endpoints
[ 2.873088] WARN::hcd_init_fiq:412: FIQ on core 0 at 0xc03b8328
[ 2.881020] WARN::hcd_init_fiq:413: FIQ ASM at 0xc03b85f4 length 36
[ 2.889230] WARN::hcd_init_fiq:438: MPHI regs_base at 0xc8808000
[ 2.897304] dwc_otg bcm2708_usb: DWC OTG Controller
[ 2.904740] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 2.914088] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 2.921591] Init: Port Power? op_state=1
[ 2.927499] Init: Power Port (0)
[ 2.933106] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 2.941980] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 2.951220] usb usb1: Product: DWC OTG Controller
[ 2.957922] usb usb1: Manufacturer: Linux 3.18.0-trunk-rpi dwc_otg_hcd
[ 2.966487] usb usb1: SerialNumber: bcm2708_usb
[ 2.974583] hub 1-0:1.0: USB hub found
[ 2.980554] hub 1-0:1.0: 1 port detected
[ 2.988776] mousedev: PS/2 mouse device common for all mice
[ 2.998105] bcm2835-cpufreq: min=700000 max=900000
[ 3.005426] sdhci: Secure Digital Host Controller Interface driver
[ 3.013657] sdhci: Copyright(c) Pierre Ossman
[ 3.020271] DMA channels allocated for the MMC driver
[ 3.053879] Load BCM2835 MMC driver
[ 3.061532] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.077415] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.085731] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.106389] usbcore: registered new interface driver usbhid
[ 3.114141] usbhid: USB HID core driver
[ 3.120596] TCP: cubic registered
[ 3.127261] NET: Registered protocol family 10
[ 3.136262] mip6: Mobile IPv6
[ 3.141481] NET: Registered protocol family 17
[ 3.148121] mpls_gso: MPLS GSO support
[ 3.156617] registered taskstats version 1
[ 3.162828] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.175057] vc-sm: Videocore shared memory driver
[ 3.181925] [vc_sm_connected_init]: start
[ 3.189230] [vc_sm_connected_init]: end - returning 0
[ 3.196875] Indeed it is in host mode hprt0 = 00021501
[ 3.204144] mmc0: new high speed SDHC card at address 59b4
[ 3.215131] mmcblk0: mmc0:59b4 NCard 7.51 GiB
[ 3.221933] /linux-3.18-3.18.5/drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 3.243630] mmcblk0: p1 p2
[ 3.255568] Freeing unused kernel memory: 332K (c0753000 - c07a6000)
[ 3.434492] udevd[67]: starting version 175
[ 3.470139] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 3.496675] Indeed it is in host mode hprt0 = 00001101
[ 4.003258] usb 1-1: New USB device found, idVendor=0cf3, idProduct=9271
[ 4.116611] usb 1-1: New USB device strings: Mfr=16, Product=32, SerialNumber=48
[ 4.270038] usb 1-1: Product: UB91C
[ 4.350577] usb 1-1: Manufacturer: ATHEROS
[ 4.426437] usb 1-1: SerialNumber: 12345
[ 4.591792] random: nonblocking pool is initialized
[ 5.203348] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 7.780405] udevd[270]: starting version 175
[ 8.695957] bcm2708_i2c_init_pinmode(1,2)
[ 8.810186] bcm2708_i2c_init_pinmode(1,3)
[ 8.895755] bcm2708_i2c bcm2708_i2c.1: BSC1 Controller at 0x20804000 (irq 79) (baudrate 100000)
[ 9.126444] bcm2708_spi bcm2708_spi.0: master is unqueued, this is deprecated
[ 9.257354] bcm2708_spi bcm2708_spi.0: SPI Controller at 0x20204000 (irq 80)
[ 9.279932] Loading modules backported from Linux version v4.1.1-0-g6a010c0
[ 9.436150] Backport generated by backports.git v4.1.1-1-0-g8286954
[ 9.865228] cfg80211: Calling CRDA to update world regulatory domain
[ 10.444961] usb 1-1: firmware: direct-loading firmware htc_9271.fw
[ 10.471918] usb 1-1: ath9k_htc: Firmware htc_9271.fw requested
[ 10.554679] usbcore: registered new interface driver ath9k_htc
[ 10.820591] usb 1-1: ath9k_htc: Transferred FW: htc_9271.fw, size: 51008
[ 10.882043] pcm512x 1-004d: Failed to reset device: -5
[ 10.922797] pcm512x: probe of 1-004d failed with error -5
[ 10.961416] pcm512x 1-004c: Failed to reset device: -5
[ 10.998439] pcm512x: probe of 1-004c failed with error -5
[ 11.052558] cfg80211: World regulatory domain updated:
[ 11.060320] cfg80211: DFS Master region: unset
[ 11.064885] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 11.082161] cfg80211: (2302000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 11.095473] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 11.108541] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 3000 mBm), (N/A)
[ 11.121931] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 11.136820] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 11.151582] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 11.165278] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 11.178673] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 11.197591] ath9k_htc 1-1:1.0: ath9k_htc: HTC initialized with 33 credits
[ 11.650872] ath9k_htc 1-1:1.0: ath9k_htc: FW Version: 1.4
[ 11.666027] ath9k_htc 1-1:1.0: FW RMW support: On
[ 11.892007] ieee80211 phy0: Atheros AR9271 Rev:1
[ 11.942207] cfg80211: Calling CRDA for country: GB
[ 12.022667] cfg80211: Calling CRDA for country: GB
[ 12.259958] cfg80211: Current regulatory domain intersected:
[ 12.294097] cfg80211: DFS Master region: unset
[ 12.306010] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 12.382091] cfg80211: (2302000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 3000 mBm), (N/A)
[ 12.422126] cfg80211: (2457000 KHz - 2482000 KHz @ 25000 KHz), (N/A, 3000 mBm), (N/A)
[ 12.466076] cfg80211: (2474000 KHz - 2482000 KHz @ 8000 KHz), (N/A, 3000 mBm), (N/A)
[ 12.510031] cfg80211: (5170000 KHz - 5250000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (N/A)
[ 12.554102] cfg80211: (5250000 KHz - 5330000 KHz @ 80000 KHz, 160000 KHz AUTO), (N/A, 2000 mBm), (0 s)
[ 12.598096] cfg80211: (5490000 KHz - 5710000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 12.642112] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 17.306778] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
